Mesh Accessories
Grove Starter Kit for Particle Mesh
The Grove starter kit is designed to make your first exploration into the world of sensing and actuating a breeze. The kit comes with seven different components that work out-of-the-box with Particle Mesh hardware and let you focus on learning the basics. Working with Starter Kit requires no soldering and minimal wiring. Simply connect the kit’s Grove Shield (the new co-developed FeatherWing adapter from Particle and SeeedStudio) to your Particle Mesh board and use the included cables to connect the adapter and the sensors and actuators that you want to use. It’s a plug-and-play experience.
Kit Contents
  • 1x Grove Shield for Particle Mesh
  • 1x Button
  • 1x Rotary Angle Sensor
  • 1x Ultrasonic Ranger
  • 1x Temp&Humi Sensor
  • 1x Light Sensor v1.2
  • 1x Chainable RGB LED
  • 1x Buzzer
  • 1x 4-Digit Display
Grove shield
The main shield consists of a connector to plug in any of the Particle Mesh dev kit and a set of 8 grove ports for plugging in various grove accessories. The ports consist of:
  • 3 Digital ports
  • 2 Analog ports
  • 2 I2C ports
  • 1 UART port
The pins on the Grove connector are as follows:
Pin Color Digital Analog I2C UART
1 Yellow Primary I/O Primary Analog In I2C Clock Serial RX
2 White Secondary I/O Secondary Analog In I2C Data Serial TX
3 Red Power Power Power Power
4 Black GND GND GND GND
For a short (~6 min) example of using the Grove Starter Kit for Particle Mesh, watch the video below.
Button
Button is a momentary push button. It contains one independent "momentary on/off" button. “Momentary” means that the button rebounds on its own after it is released. The button outputs a HIGH signal when pressed, and LOW when released. The Sig marked on silk layer stands for signal while NC is not connected to anything.
It can be used on either a digital or analog input port, and the button is read using the primary digital I/O using the digitalRead function. The digitalRead function can be used on both digital and analog pins.
Additional information available here.
Rotary Angle Sensor
The rotary angle sensor produces analog output between 0 and Vcc (3.3VDC) on its D1 connector. The D2 connector is not used. The angular range is 300 degrees with a linear change in value. The resistance value is 10k ohms. This essentially is a potentiometer.
It must be used on an analog input port, and the value is read using the primary analog input using the analogRead function.
Ultrasonic Ranger
Ultrasonic ranger is a non-contact distance measurement module which works at 40KHz. When we provide a pulse trigger signal with more than 10uS through signal pin, the sensor will issue 8 cycles of 40kHz cycle level and detect the echo. The pulse width of the echo signal is proportional to the measured distance. Here is the formula: Distance = echo signal high time * Sound speed (340M/S)/2. The sensor's trig and echo signal share 1 SIG pin.
The library is available in the Web IDE as Grove_Ultrasonic_Ranger.
Temperature and Humidity Sensor
This Temperature and Humidity sensor provides a pre-calibrated digital output. A unique capacitive sensor element measures relative humidity and the temperature is measured by a negative temperature coefficient (NTC) thermistor. It has excellent reliability and long term stability. Please note that this sensor will not work for temperatures below 0 degrees. It uses the DHT-11 sensor.
The library is available in the Web IDE as Grove_Temperature_And_Humidity_Sensor.
Light Sensor v1.2
Light sensor integrates a photo-resistor (light dependent resistor) to detect the intensity of light. The resistance of photo-resistor decreases when the intensity of light increases. A dual OpAmp chip LM358 on board produces voltage corresponding to intensity of light(i.e. based on resistance value). The output signal is analog value, the brighter the light is, the larger the value.
This module can be used to build a light controlled switch i.e. switch off lights during day time and switch on lights during night time.
Chainable RGB LED
Chainable RGB LED is based on P9813 chip which is a full-color LED driver. It provides 3 constant-current drivers as well as modulated output of 256 shades of gray. It communicates with a MCU using 2-wire transmission (Data and Clock). This 2-wire transmission can be used to cascade additional Grove - Chainable RGB LED modules. The built-in clock regeneration enhances the transmission distance. This Grove module is suitable for any colorful LED based projects.
The library is available in the Web IDE as Grove_ChainableLED.
Buzzer
Buzzer module has a piezo buzzer as the main component. The piezo can be connected to digital outputs, and will emit a tone when the output is HIGH. Alternatively, it can be connected to an pulse-width modulation output to generate various tones and effects.
You can use the pinMode and digitalWrite functions to control the output.
pinMode(D2, OUTPUT);
digitalWrite(D2, HIGH);
delay(1000);
digitalWrite(D2, LOW);
It can be used on a digital or analog port, as the analog inputs can also be used as digital outputs.
An example using tone (PWM) to play a melody can be found here. Not every pin is PWM compatible, so make sure you use a port that supports PWM.
4-Digit Display
This is a 4 digit seven-segment display module that uses TM1637 driver chip. This driver is controlled with a two wire interface (CLK, DATA). This is perfect for displaying 4 digit numeric values.
The library is available in the Web IDE as Grove_4Digit_Display.
Adafruit FeatherWing OLED Display 128x32
The Adafruit OLED display FeatherWing makes it easy to add a small text and graphics display to your project. Built in a FeatherWing form-factor, you can use a FeatherWing Doubler or FeatherWing Tripler to add a display to your Argon, Boron, or Xenon project with no loose wires. And it includes three handy momentary push-buttons.
You can purchase one from the Particle Store or from Adafruit. You can find more technical information at Adafruit.
The library is available in the Web IDE as oled-wing-adafruit. You can find additional documentation here.
The display is a SSD1306 and connects by I2C (pins D0 and D1).
The three buttons are:
Button Pin Notes
A D4 No pull-up. Can't be used with Ethernet.
B D3 100K pull-up. Can't be used with Ethernet.
C D2 No pull-up.
The library takes care of setting the appropriate input modes and debouncing the buttons for you.
Note that if you are using the Adafruit OLED display and the Particle Ethernet FeatherWing, you cannot use buttons A or B as those pins are used by Ethernet.
The Ethernet FeatherWing is the fastest way to add wired connectivity to your Argon, Boron, or Xenon and turns any Particle Mesh developer kit into an Ethernet gateway. Based on the WIZnet W5500 chip, this side-by-side FeatherWing maintains great RF performance even while adding Ethernet connectivity to any Particle Mesh device.
The form-factor is based around the Adafruit FeatherWing Tripler. The two side connectors allow you to plug in one Particle Mesh device along with a Feather accessory.
Pin Map
Mesh Pin Ethernet FeatherWing Pin
MISO SPI MISO
MOSI SPI MOSI
SCK SPI SCK
D3 nRESET[1]
D4 nINTERRUPT[1]
D5 nCHIP SELECT[1]
[1] These pins are connected via jumper pads on the bottom. You can cut these jumper traces and rewire them to a different pin on the Mesh device if the need arises.
The Ethernet driver for this wing is baked into the Mesh Device OS. When you set up a new Particle Mesh device that is plugged into an Ethernet FeatherWing, simply select the USE WITH ETHERNET? option on your Particle mobile app and it should recognize and talk over Ethernet automagically. It's that simple.
The hardware design for this wing is completely open source. All the files are available on our GitHub repository here.
If you are using the Adafruit Ethernet Feather Wing, be sure to connect the nRESET and nINTERRUPT pins (on the small header on the short side) to pins D3 and D4 with jumper wires. These are required for proper operation.
Classic Adapter
The Particle Classic Adapter lets you use your Asset Tracker, Relay Shield, or other third-party shields with our third generation developer kits. Plug your Argon, Boron, or Xenon into this adapter and continue development as usual!
The top of the adapter has female connectors for you to plug in the Particle Mesh device. The bottom has male header pins in the Particle legacy form-factor for devices such as the Electron, Photon, or the Core.
The legacy side (male pins on the bottom) are designed to fit an Electron. So when plugging into a Photon socket please make sure the B/C pins side are hanging off the end, not plugged into anything.
You cannot supply more than 3.3V to any pin on the Argon/Boron/Xenon (except VUSB and the USB connector).
Note: This product is a one-way adapter. That is, this product does not enable use of Adafruit FeatherWings with the Photon or Electron.
The design is open source and the design files are available here.
Additional details and diagrams
Pin Map
Legacy Device Mesh Device
A0 A0
A1 A1
A2 A2
A3 A3
A4 A4
A5 A5
D0 D0 (SDA)
D1 D1 (SCL)
D2 D2
D3 D3
D4 D4
D5 D5
D6 D6
D7 D7
C5[1] D8
TX TX
RX RX
B5[1] D11 (MISO)
WKP[1] D12 (MOSI)
DAC[1] D13 (SCK)
RST RST
VIN VUSB
3V3 3V3
[1] These pins are connected via jumper pads on the top. You can cut these jumper traces and rewire them to a different pin on the Mesh device if the need arises.
[2] Pins C0 to C4 and B0 to B4 on the Particle legacy device headers are not connected to anything.
[3] Pins MD, Li+, and EN on the Particle Mesh device are not connected to anything.
I2C
I2C (Wire) can be used on D0 and D1. However, pins on the mesh devices are not 5V tolerant, so make sure you do not have pull-ups to 5V.
SPI
It's not possible to use SPI with the classic adapter. The mesh SPI pins (MISO, MOSI, SCK) are not connected to pins that support SPI on the Electron or Photon (B5, WKP, DAC). The mesh SPI1 pins overlap the Electron/Photon SPI1 pins, however they're different!
SPI1 Classic Mesh
SCK D4 D2
MOSI D2 D3
MISO D3 D4
Other Features
The mesh devices do not support DAC or CAN, so those classic devices using those features won't work with the classic adapter.
Debugger
The Particle Debugger gives you the power of professional debugging at a fraction of the cost. Using this accessory, you’ll be able to program Particle mesh-ready hardware over common interfaces like JTAG and SWD, using open source tools like GDB and openocd.
Supports the open source CMSIS-DAP specification and DAPLink firmware developed by ARM. On Mac, Linux, and Windows it requires no additional device drivers.
It also provides a USB to TTL serial port. This requires no device drivers on Mac, Linux, or Windows 10 or later, but you may need to install a device driver for earlier versions of Windows to use the serial port feature.
Comes with one JTAG ribbon cable.
For more information about debugging see the JTAG FAQ. Future version of Particle Workbench will support the Particle Debugger as well. The design is open source and the design files are available here.
Debugging mesh devices
Connecting a Argon, Boron, or Xenon to the debugger is as easy as connecting the included ribbon cable, as pictured below. It's keyed so it will only go in one way. The devices ship with a small plastic protective plug in the debugging connector; make sure you remove that first.
Debugger
Debugging legacy platforms
Using the headers on the Particle Debugger you can attach it to other ARM processor devices like the STM32 in the Particle Photon, P1, Electron, and E Series for SWD (serial wire debug).
With the debugger positioned like this, USB connector toward you and the headers facing up:
Debugger
Left Header Right Header
VDD SWCLK
RTS SWDIO
RX NC
TX NC
CTS GND
GND VUSB
In order to use SWD debugging you need to connect:
  • D7: SWDIO
  • D6: SWCLK
  • GND
FeatherWing Tripler
Perfect for any prototyping project, the Tripler provides space to add-on up to two FeatherWing accessories without any stacking header needs. Compatible with the newest generation of Particle developer kits (Particle Mesh).
The Tripler has three breakouts for each pin on a Feather, as well as plain grid proto holes. In addition, three sets of pins are cross connected with a full strip of connected pads for GND and 3.3V.
